Re: honda PA50 II ideas
Don Pflueger /
two thingsare possibly bad.
cranksealon the magneto side
leaking cylinder base gasket.
try to retorque the head bolts to 10 ft/lbs. if that doesnt help, get a new base gasket and crankseal from www.partsfish.com. the reason theengine wont idle is because it is losing vacuum at low rpm and cannot draw fuel from the carb to maintain idle. it is possible that thecarb has a dirty idle circuit. but if you cleaned thecarb thoroughly, and ran a piece of wire thru every hole in the carb body and its parts, you should be ok. putting the bowl on backwardscauses the float to bind and affects all ranges of rpm.
