Re: honda PA50 II ideas
Frank Garland /
My guess is the carb still has issues. Make sure the float bowl is installed correctly. Nowhere in the tech data does it tell you that you can install it 180 out. THe fuel drain on the exterior(float bowl) should be point to the right!
