Re: fa50 oil pump isnt working
Bob Diehl /
Good idea, but you could also replace the oil lines to see if there is an obstruction or some other damage to the lines. Also use a wire to clean out the fittings all along the way. Then a little air to blow things out. Plus, I think I read that you must "prime" the oil pump once you have worked on it. Check the manual for details.
