Anyone know anything about Honda S65's?
Robert Gosnell /
Hello,i have a 1968 Honda s65 motorcycle/scooter.I guess you can classify this as a scooter because it is a two stroke.My problem with the bike is that i think im not getting enough ground on the electrical.When they say a ignition is internally grounded,where is the grounding point?the coils?the condensor?So if anyone has any opinions let me know.i would like to get this bike up and running.
thanks
robert
Re: Anyone know anything about Honda S65's?
Leon Swarmer /
First of all, I bet it isn't two stroke.
see
http://100megsfree4.com/honda/h0051/sport65.htm
You have a 4 speed, ohc, manual clutch motorcycle.
the entire frame is the ground on this bike.
Check the battery, buy a new plug and points.
points are behind the circle plate on the left side of the bike.
Near the kick starter there is a screw in dipstick. Unscrew it, wipe it off put it in without screwing it in and take a reading.
Good luck,
Looks like fun.
Leon
If its the original motor its not a two stroke, it is a 70cc 4 stroke, everything 50 said, what do you mean by not getting enough ground? What is happening? You can find the manual online, it is the same motor used on the CT70-H and several other bikes, I can probably link you to one if you need it.
The Honda 65 makes me drool.................I have always loved that little motorcycle, and DON'T call it a `snail'! don-ohio
