Re: moped wont stay running hard problem
Don Pflueger /
crank seals are located in thecase where the crank shaft comes out. it is the black rubber seal. crank seals maintain crank case pressureand vacuum.
it is possible that your piston is in upside down too. when you pulled thecylinder off, did you replace the base gasket and torque the head bolts to 10 ft/lbs?
