1979 urban express lighting help
Hello, my 1979 urban express is running great for me except one thing. The headlight only works on high beam, the blinkers go on but don't blink 90% of the time, and when they do blink, the right side is much stronger then the left. I changed the battery thinking it was just low on juice but it hasn't helped. I checked all the wires and they look fine. Is it just the bulbs that need replacing or is there something more that I'm missing? Thanks for the help.
Nick
Re: 1979 urban express lighting help
Anthony Castellanos /
yea man sounds like you need some new l ight bulbs.
Robert Wright /
I'm no expert but my mechanic recently told me that running the Express with a weak battery would blow the headlight. If you ran it before changing the battery, that may be the problem with the head light and the blinkers.
Leon Swarmer /
Have you run a voltmeter on the battery? Should be 6 volt at rest and kick up to over 7 when you first start it up at a fast idle.
Leon
Thanks guys for your help, I really appreciated it and will definitly give your suggestions a try.
Nick
