Re: running with no heat shield
Don Pflueger /
heat shields are designed to direct air flow around hot areas on an engine block. the air flow usually comes from a fan mounted to the flywheel, or just out side air as the engine runs and the bike is being ridden. its not the best idea to remove them.
