running with no heat shield
I own a 82 ohnda express, and recently just lost the heat shield. IS it bad to run without one?
thanks, Nate
Re: running with no heat shield
Don Pflueger /
heat shields are designed to direct air flow around hot areas on an engine block. the air flow usually comes from a fan mounted to the flywheel, or just out side air as the engine runs and the bike is being ridden. its not the best idea to remove them.
Leon Swarmer /
Nate,
are you talking about the heat shield on the side of the muffler?
Leon
Nate Green /
yeah
doenst mind...
just be carrefull not to toutch the exhaust...it can be hot hot hot!
be carefull
g.b.
Leon Swarmer /
I think it is for protecting the driver and not for the sake of the ped.
Don P is right in other cases.
Leon
