wiring
Paul Joseph /
I have a sachs motor with 3 wires red/white & yellow & black.
i'm chaging it to a trac moped that looks the same but has 5 wires not 3 and they are white & black/red & green & blue & blue/white what wire goes were?????????????
PLEASE HELP PLESASEEEEEE
Re: wiring
Don Pflueger /
if they fit, why not just swap the stators? then you can use the original wires. otherwise, i think you will have nothing but problems.
Re: wiring
Are they both engines with ignition points? Some of those TRACS were electronic ignition. don-ohio
Re: wiring
white is the return which completes the path and brings power back. green is the ground. black is your hot which gives you power
Re: wiring
Don Pflueger /
that sounds like house wiring to me.
