Re: Honda PA50 - won't idle, max speed of 12MPH?!
Brant J /
mine's doing the same thing now, my thoughts are: the passage from the welch plug (behind it) to the air mixture screw may be blocked, or restricted, or possibly right under welch plug, or maybe in your case the tube from the front of that carb to the chamber under the welch plug may be blocked, all have to do with idle, good luck..
p.s. the 12mph thing sounds like a variator issue though, so this could be two seperate issues manifesting as one.
p.s. oh yeah and if you are going to disassemble again, don't forget to clean the emulsion tube...
