Re: Honda PA50 - won't idle, max speed of 12MPH?!
Frank Garland /
Did you confirm the float bowl is on correctly? It it isnt, it will interfere with the travel of the float and your fuel flow...Drain screw points to the right of the moped...You can just lay down and visually check it!
