CDI Spark Problems...
Matt Freeman /
So my QT50 is having problems. Today it would not start for all the kicking in the world and I have narrowed it down to a spark problem. The spark, if present at all is very very weak, so weak that it is extinguished when gas enters the chamber (assumption)
So this is what I have done...
-Cleaned all electrical contacts between magneto and CDI
-Verified connection through bike between CDI and magneto
-Swapped out CDI for known working one
-Swapped out magneto for known working one
-Swapped out plug for known working one
-Verified AC voltage at the plug cap
Even with all this, the problem still persists. Any combination or permutation of the above will occasionally yeild a spark and other times nothing at all.
Quite simply I'm out of ideas. Is there anything else you can do to a CDI? Any help you could shed on the subject would be greatly appreciated.
On a side note... thoughts on the best way to loosen stuck screws and the difficulty of a kickstart replacment.
Wishing for some points to clean...
-Matt
