how do i remove the front sprocket?
does anyone know how 2 take it off and if they have a new one for a minirelli cause it a pain and i wanna get her going again.
KEvin
Re: how do i remove the front sprocket?
can anyone help?
See Ya Moped Army /
Once you remove the nut, it should pull off. It may take a little leverage from behind to pop it off.
no the bar spins with it so its not coming off and the sprocket is stripped on the inside so i cant get it off.
plz help
Leon Swarmer /
not exactly clear on the problem... "sprocket is stripped on the the inside>
Are you telling us it won't hold a chain? If it will hold a chain, but the chain on and run it to to the backwheel and have someone hold the brake while you try to undo the nut.
If it won't hold a chain can you clamp a pair of vice-grips on the the spocket and them loosen the nut.
Leon
Steve Murphy /
Can you use a small gear puller? They're pretty inexpensive and most auto parts stores have them.
