Re: how do i remove the front sprocket?
Leon Swarmer /
not exactly clear on the problem... "sprocket is stripped on the the inside>
Are you telling us it won't hold a chain? If it will hold a chain, but the chain on and run it to to the backwheel and have someone hold the brake while you try to undo the nut.
If it won't hold a chain can you clamp a pair of vice-grips on the the spocket and them loosen the nut.
Leon
