KINETIC HELP
Kelly Kass /
so i pulled a kinetic out from under a porch tonight where it sat for 4 years since it had been wrecked. its a tfr, 96 maybe? so anyways, i put a new plug in it, new gas, it has strong compression, how do i start this thing? the headlight which had been messed up from the wreck was all taped up, i cut the tape off and discovered that there is a key ignition. i do not have the key. it had been all taped up over, so im under the impression that it ran after that without using the key. can you turn the key to "ignition" and then take it out? i read the manual that cosmo whatever had to download and i also found out there is a "decompressor", which i didnt notice on my bike until further inspection since it had been broken off. i mean, do you even need that? any help you guys have to offer would be great. lets get this thing poppin off
