Hole in carb float
I got a 1983 honda passport. Its linking all over the place and we pinpointed that there was a hole in the float. Because the float would get logged there was no restriction on how much gas was flowing. I tried to use an epoxy for plastic, but it only held for a day. I'm assuming that it isn't gas resistant. Is there anyt other kind of epoxys, glues, or sealants that would be able to handle the gasoline.
thanks
josh
Re: Hole in carb float
Leon Swarmer /
http://dratv.com/floatplas197.html
This is prolly what you need. I've used gasket sealer and it worked for a little while, but it was not on a carb float near an exhaust pipe.
This would be a whole lot safer..check for fit.
Leon
Is it a plastic or metal float? I believe that JB weld would work fine in the gas, I'm not 100% sure how well it works with plastic, but if done right on metal it works great, I am using some on a carb right now.
Jim Fitzgerald /
I used Krazy Glue on my plastic float, and it worked for over a week before I replaced it. Who knows how long it would have lasted if I had just left it in...When I took it out there was no gas inside the float, so Krazy Glue might be a good choice...
Seal All glue seems to work in gas. I have used it on car gas tanks with a metal screw and it last forever. I should work on plastic if it doesn't melt it.
i have an old bing carb you can have for $15
if you need it
ive heard solder works well
