airsal kit tomos a3n
alright im pretty sure im going to buy a airsal kit for my tomos a3n..heres the question...my a3n has a two bolt manifold and no reed valve...and a stock carburator...do i need a bigger carb and with this kit will i have to get a new reed valve manifold "four bolt"
for this kit to work, what about a high performance exaust?
thx for your help,
mike c
Re: airsal kit tomos a3n
Don Pflueger /
the airsal kit should come with the intake manifold and reed valve. your stock carb fits right on it.
thx for your help,
mike c
John Joedicke /
If it is just the basic Airsal jug kit it will not come with a intake manifold, which is 4 bolt to accomadate the new reed valve.
Don Pflueger /
really? i thought they did. sorry mike.
What you can do is buy the A35 manifold and use that. The stock carb should be able to fit it and the kit comes w/ a reed valve. A Performance exhaust would be good idea to get also.
i hear that you made need to change the jets on the stock carb to get it running good. and make sue you get the right spark plug which i beleive is an Autolite 275
