Re: QT50 gas leaking out overflow
Randall F /
Maybe your float is bad?
As far as I know, a bad fuel valve wont cause that... but if your float is stuck open, or the needle or whatever, gas will just keep flowing. Granted, with a moped its not much but its enough.
Check the float and the throttle tension and the spring...
