Can't get my pedals off Help!
THis is off of a puch maxi. I broke the pedals and not sure how to get it off. I' ve soaked the piece in WD-40 hoping it was just rusted on. The thing won't budge. Is it thredded? Is it one piece? The pedal was broken once before and was welded back on. THere is a weld connecting the sprocket to the bar. I think that this is an original weld but can't tell. I've got more pictures if they didn't all load.
THanks in advance
Re: Can't get my pedals off Help!
Don Pflueger /
"The pedal was broken once before and was welded back on."
umm, if it was welded back on once before, i doubt it will ever come off again.
thats not what i meant. The actual pedal arm was welded back together
You are not getting the pedal crank off of the sprocket and shaft, they are welded together, that is how it is made.
Don Pflueger /
ok. well, if the crankarms are mounted on the correct sides, use a 15mm wrench, and while sitting on the bike, turn both sides towards the back of the bike from the top.
grind any welds off, and you may need to drill the set pin out if it doesn't come out if there is one, its a piece about an inch long
