Re: a3n bearing changes?
Don Pflueger /
you need to talk to ike about which bearing you need. some a35's came with 10mm or 12mm bearings depending on which assembly line they came from. th airsal kit is designed for the a35, but will fit the a3n with the rod bearring change, and the kitted a3n is second to none.
