clutch arm stays engaged
Ramsey Beyer /
hi. i just finally figured out my clutch cable for my 1977 puch maxi, one speed. the cable pulls the clutch arm forward to engage it but my clutch arm sticks and wont return into position so it doesnt turn over into gear correctly. ive tried spraying wd40 on the arm to loosen it up. is there some sort of spring or something that helps it return? maybe this could be worn out? how can i get my clutch arm to return to normal position after the bike has started.
thanks for any tips!
Re: clutch arm stays engaged
There is a SPRING inside the tranny that returns it. Check for a binding starter clutch cable or a problem inside the tranny. don-ohio
Ramsey Beyer /
thanks so much. i'll look into it today.
