Re: cateye turn signal repair
Don Ohio /
You lightly solder 2 wires to the proper terminals of the box where the batteries sit..............you attach alligator clips(an actual plug end is better) to the ends.....one red(positive),one black(ground). You then find any power source(Radio Shack has universal ones with adjustable outputs and voltages) that plugs into the wall and is greater than 200 MAmp and up to 1000 Mamps, and connect it positive to positive,negative to negative. I keep a timer here that I can set for 6-8 hrs.charging on my lawnmower battery. 6-8 hrs. is a good charge time for most Ni-Cads.
don-ohio
  cateye turn signal repairTopic by: David S David S 08/31/04 06:39PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 08/31/04 06:55PM
  Re: cateye turn signal repairRe: David S David S 09/01/04 09:35PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 09/03/04 12:59AM
  Re: cateye turn signal repairRe: Ray West Ray West 09/03/04 01:22AM
  dot dot dotRe: Randall F Randall F 09/03/04 03:09AM
  Re: cateye turn signal repairRe: Bill W Bill W 09/03/04 05:52AM
  My cat was wired wrongRe: Bill W Bill W 09/03/04 06:01AM
  Re: cateye turn signal repairRe: Randall F Randall F 09/03/04 06:26AM
  Re: cateye turn signal repairRe: Ray West Ray West 09/03/04 04:01PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 09/03/04 10:19PM
  Re: cateye turn signal repairRe: Ray West Ray West 09/03/04 11:32PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 09/05/04 12:48AM
  Re: cateye turn signal repairRe: Randall F Randall F 09/05/04 09:18PM
  Re: cateye turn signal repairRe: Ray West Ray West 09/05/04 09:31PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 09/05/04 11:04PM
  Re: cateye turn signal repairRe: Randall F Randall F 09/05/04 11:49PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 09/07/04 10:23AM
  Re: cateye turn signal repairRe: David S David S 09/07/04 07:00PM
  Re: cateye turn signal repairRe: Don Ohio Don Ohio 09/08/04 09:57AM
  Re: cateye turn signal repairRe: Randall F Randall F 09/04/04 01:25AM
  Re: cateye turn signal repairRe: David S David S 09/04/04 04:13PM
  Re: cateye turn signal repairRe: Randall F Randall F 09/05/04 05:12AM
  Re: cateye turn signal repairRe: David S David S 09/05/04 08:52PM
  Re: cateye turn signal repairRe: David S David S 09/07/04 07:39PM
  Re: cateye turn signal repairRe: David S David S 09/07/04 08:00PM
