Re: idles, but won't push up into higher rpms...he
Don Ohio /
Okay.....this is no insult, but it has happened plenty of times.......are you sure you have the piston in there correctly? Sometimes they'll run even if the arrow on the crown of the piston is not facing DOWN toward the exhaust port like it should be. Seen it happen before. don-ohio (:^)
