tomos targa lx transmission problem
OK well if i gun my moped sometimes I will get a rough grinding from my transmission then i have to let off the gas and put it back on to get it to go normal. This also seems to happen going up dirt hills sometimes. Well it happened to me yesterday and I wanted to make sure I got up the hill so I didnt let off the gas just let it grind for a sec. Stupid of me, well now the transmission stays in first gear instead of going to neutral so now my moped wont idle without giving it gas and holding on the breaks(but it will still shift up to second). I took off the cover yesterday and there were no obvious problems although I have never looked at the insides of a transmission before :) I put it back together and put oil back in it. I was hoping maybe someone knew what was wrong with it and a way to fix it.
Thanks!
Justin
Re: tomos targa lx transmission problem
bump* anyone i miss my ped :(
Try putting a new 1st gear clutch on.
Leppy The Lepracaun /
no sweat, i got the same problem i think. jus ease off the gas it should shift.
no it isnt that is does shift to second it is that is doesnt shift back down to neutral
Thanks for the replies
Friend has the same problem cause the oil hasn't been changed in 4 years cause he doesnt know how. That's why I thought he had the problem
well i changed mine and it still doesnt work i guess i will replace the first gear clutch
