Re: my '81 motrin won't start
Don Pflueger /
just be sure to get actual compression numbers and not go by the thumb trick when checking compression.
most likely your carb needs to be cleaned out and things like the head bolts and intake manifold need to be torqued down. head bolts are 10 ft/lbs.
