Wiring Diagram?
I need a wiring diagram for my 1980 puch newport 2, I need to know where the wires that come from the taillight connect into the system.
The diagram that I had linked isnt online anymore :(
Any help is appreciated...
Thanks!
-Rand
Re: Wiring Diagram?
hope this will help you good luck!!!
Franky-d
Re: Wiring Diagram?
sorry the attachement didnt work
Re: Wiring Diagram?
Re: Wiring Diagram?
Randall F /
Wow... that is going to suck incredibly. Guess I will wait till I have the wiring harness off this winter to fix it.
Re: Wiring Diagram?
Randall F /
Hrm... now that I think about it, it might be brown wire coming from the taillight... I guess thats ground? If it is ground, its not workin heh.
Re: Wiring Diagram?
yeah the brown wire is the ground
Re: Wiring Diagram?
Randall F /
The wire runs all the way from the taillight, under the rear fender and all the way up through the center of the forks where it is split off...
Where is it supposed to connect to?
It is a 'brown' wire, but it looks more like speaker wire than the other wires that are on the bike... it is a 'two wires in one' kinda job.
Re: Wiring Diagram?
is this the wire for the brake bulb ? if it his i think it should be conected to the brake light switch the switch is near were the cable enter the handle and there should be a black ruber cover
Franky-d
Re: Wiring Diagram?
Here's one for a 77, should be the same.
