Re: puch front wheel bearing play
Don Ohio /
Glad you got `er fixed..............just remember that on loose ball bearing set-ups, you must have a little play, or you'll bind the balls,causing premature wear and dragging.
Just a teensy bit of play,you can barely feel it, and that is the correct adjustment for wheel bearings. don-ohio (:^)
