Tomos Pedal Crank
Leppy The Lepracaun /
Any idea how to take off the pedal crank on a TTLX? i took the nut off the screw but im not sure if u tap out the screw or turn it or whatever.
Re: Tomos Pedal Crank
Take a hammer and hammer it out. No, I'm not jokeing.
Ben Van Zoest /
Support the crank and shaft w/ a wooden block solidly, leave nut on just a tad above the wedge thread than tap nut/wedge loose.
oh aight. thanx guys. time to put some new pedals on.
If it is on there really stubornly hit it on the side without the nut on it several times. No kidding. Although this will drive the pin in further it will also break any bond from rust or whatever, so that you can get it out by hitting it again on the threaded side.
