Re: Motobecanes and Dellorto Carbs
Bort Hoff /
If you have a variator, you will benefit from a larger dellorto. The 15/15 needs a shim to fit properly, while the 16/16 fits perfectly on the hook-shaped manifold. However, the 16/16 will make you bike idle high unless you switch to a different throttle assembly, like Magura or Domino.
I'm pretty sure any cylinder will benefit from a larger carb, the larger-ported ones more so.
  Motobecanes and Dellorto CarbsTopic by: Bill Cassidy Bill Cassidy 08/23/04 11:58AM
  Re: Motobecanes and Dellorto CarbsRe: Don Ohio Don Ohio 08/23/04 02:44PM
  Re: Motobecanes and Dellorto CarbsRe: Eric Barker Eric Barker 08/23/04 03:11PM
  Re: Motobecanes and Dellorto CarbsRe: David Emery David Emery 08/23/04 03:36PM
  Re: Motobecanes and Dellorto CarbsRe: Eric Barker Eric Barker 08/25/04 09:26PM
  Re: Motobecanes and Dellorto CarbsRe: John John 08/23/04 04:25PM
  Re: Motobecanes and Dellorto CarbsRe: Bort Hoff Bort Hoff 08/25/04 04:38AM
  Re: Motobecanes and Dellorto CarbsRe: See Ya Moped Army See Ya Moped Army 08/25/04 10:41PM
  Re: Motobecanes and Dellorto CarbsRe: Bort Hoff Bort Hoff 08/26/04 06:14PM
  Re: Motobecanes and Dellorto CarbsRe: Eric Barker Eric Barker 08/26/04 08:24PM
  Re: Motobecanes and Dellorto CarbsRe: Rod Rod 06/15/07 06:29PM
  Re: Motobecanes and Dellorto CarbsRe: Mabecane1978 Mabecane1978 06/15/07 06:36PM
  Re: Motobecanes and Dellorto CarbsRe: Mabecane1978 Mabecane1978 06/15/07 06:38PM
  Re: Motobecanes and Dellorto CarbsRe: keller_stephen keller_stephen 06/15/07 06:40PM
  Re: Motobecanes and Dellorto CarbsRe: dsw dsw 06/15/07 11:50PM
  Re: Motobecanes and Dellorto CarbsRe: Rod Rod 06/16/07 02:19AM
  Re: Motobecanes and Dellorto CarbsRe: Mabecane1978 Mabecane1978 06/16/07 09:28AM
  Re: Motobecanes and Dellorto CarbsRe: Mabecane1978 Mabecane1978 06/16/07 09:29AM
  Re: Motobecanes and Dellorto CarbsRe: Mabecane1978 Mabecane1978 06/16/07 09:37AM
