puch clutch problem
Rayn Kozikowski /
on my 1 speed puch i enguage the clutch and pedal, the flywheel spins backwards! but when i push the moped backwards the flywheel spins normal! whats wrong?????????
ryan
Re: puch clutch problem
no, cause the engine when running, rotates backwards, so if you push it backwards it will rotate forwards. Its working fine.
Jason Luther /
yup, the flywheel turns clockwise when running normally
