carb trouble
Garrett Scheffler /
my tomos targa lx has a amal carb on it and is kinda screwed up and i dont know how to fix it. it wont let me full throttle cause my moped stalls when i do, but when pull my choke when i full throttle the moped runs fine like it used to. i think i need to adjust the choke or something but i dont know how. can someone please help me
Re: carb trouble
just go out and buy a new carb, since their can be many problems in the carb that could affect your performance.
Re: carb trouble
You are most likely running very lean. Try installing larger jets.
Re: carb trouble
Don Pflueger /
first, why does it have an amal carb? tomos uses dellortto or encarwi carbs. second, the problem could be numerous things. sounds like it has incorrect jetting for your engine. but, with it being the wrong carb for your bike, its hard to say where to start.
Re: carb trouble
Don Pflueger /
cory, i like your answer. buy a $70 carb when it may just be a $3 jet that needs to be replaced. lol he should get the correct dellortto carb anyway.
Re: carb trouble
Ben Van Zoest /
You said IF I choke it runs good, what does that tell U!!!
MIXTURE PROBLEM.
Re: carb trouble
Garrett Scheffler /
yeah but i have had it installed for a few months and it used to work fine. so it cant be the jet cause i had the same one ever since i got the carb.
Re: carb trouble
Ben Van Zoest /
Sorry, I throw in my hat. I am too confused today....
Re: carb trouble
Don Pflueger /
tighten up the intake manifold bolts.
