Re: Cant go over 50% throttle...Stalling
Randall F /
This might not be much help, but if 'some fuel comes out', as in, it is actually .leaking. fuel, then you need to get that taken care of before anything else... you should also just put in a brand new fuel line, they are cheap as dirt.
If it just dies at over 50% throttle, as far as I know it could be a lot of things, but most likely are timing (if it is off just the right ammount it might work at lower rpm's) and dirty carb.
Clean the carb first and try some 93 octane gas, because as I read before, it combusts at a higher temp, and will help to keep the piston from compusting the gas rather than the spark plug, IF that is the problem.
So... clean the carb, good gas premix (PRE MIX IT!), check the fuel valve, new fuel line, in-line filter, and if all that doesnt help, check the timing and clean the points.
Most of that is general maint. stuff anyway, no reason not to do it, especially the fuel stuff if you are having problems.
  Cant go over 50% throttle...StallingTopic by: Graham Mcmillan Graham Mcmillan 08/21/04 08:11PM
  Re: Cant go over 50% throttle...StallingRe: Joe Woods Joe Woods 08/21/04 08:56PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/21/04 09:08PM
  Re: Cant go over 50% throttle...StallingRe: Robert Dingman Robert Dingman 08/21/04 11:04PM
  Re: Cant go over 50% throttle...StallingRe: Joe Woods Joe Woods 08/21/04 11:37PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 04:30PM
  Re: Cant go over 50% throttle...StallingRe: Jason Luther Jason Luther 08/22/04 06:36PM
  Re: Cant go over 50% throttle...StallingRe: Ben Van Zoest Ben Van Zoest 08/22/04 08:40PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 08:46PM
  Re: Cant go over 50% throttle...StallingRe: Bill W Bill W 08/22/04 09:34PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 09:50PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 09:54PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 09:55PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:06PM
  Re: Cant go over 50% throttle...StallingRe: Jason Luther Jason Luther 08/22/04 10:30PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:34PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 10:35PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:42PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/23/04 12:21AM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/23/04 12:21PM
  Re: Cant go over 50% throttle...StallingRe: Ben Van Zoest Ben Van Zoest 08/24/04 01:59AM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/24/04 04:50AM
