Re: Cant go over 50% throttle...Stalling
Graham Mcmillan /
Thanx for the fast reply.
Ill check the compression tomorrow. Since i dont have a tester, ill just use my thumb. When i was putting it back together, i made sure all the hoses etc were completely on. Also checked the carb when the throttle needle was put back in and all seemed fine.
It took forever to start, ended up having to kickstart it. Even when it moves, there's barely any power. How would you recommend cleaning a carb? I just used spray cleaner. It seemed clean, but i suppose you can never tell.
Somebody mentioned it could be my variator, since my bike is an automatic. I was messing around with the variator last week to see if it was derestricted, but i dont think i damaged anything. Besides, it's been down on power well before then. I guess ill check it's getting into top gear anyway. But as you said, cleaning the carb shouldnt make the problem worse, so it must be carb related.
  Cant go over 50% throttle...StallingTopic by: Graham Mcmillan Graham Mcmillan 08/21/04 08:11PM
  Re: Cant go over 50% throttle...StallingRe: Joe Woods Joe Woods 08/21/04 08:56PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/21/04 09:08PM
  Re: Cant go over 50% throttle...StallingRe: Robert Dingman Robert Dingman 08/21/04 11:04PM
  Re: Cant go over 50% throttle...StallingRe: Joe Woods Joe Woods 08/21/04 11:37PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 04:30PM
  Re: Cant go over 50% throttle...StallingRe: Jason Luther Jason Luther 08/22/04 06:36PM
  Re: Cant go over 50% throttle...StallingRe: Ben Van Zoest Ben Van Zoest 08/22/04 08:40PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 08:46PM
  Re: Cant go over 50% throttle...StallingRe: Bill W Bill W 08/22/04 09:34PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 09:50PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 09:54PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 09:55PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:06PM
  Re: Cant go over 50% throttle...StallingRe: Jason Luther Jason Luther 08/22/04 10:30PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:34PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 10:35PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:42PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/23/04 12:21AM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/23/04 12:21PM
  Re: Cant go over 50% throttle...StallingRe: Ben Van Zoest Ben Van Zoest 08/24/04 01:59AM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/24/04 04:50AM
