Re: Cant go over 50% throttle...Stalling
Joe Woods /
Assuming you did absolutely nothing unusual to the bike, something may have come loose.. check for vacuum leaks and check compression.
The bike could be starving for fuel.. check fuel flow from top to bottom.. Start with the vent in the gas cap and work your way down.
Properly cleaning a carb cannot make a bike run worse.. you may want to clean it again. But since your 'cleaning' made a negative impact, this might be a clue. There's a chance that the carb is the problem and you aggravated it, perhaps by pushing a piece of crud deeper into a passage.
  Cant go over 50% throttle...StallingTopic by: Graham Mcmillan Graham Mcmillan 08/21/04 08:11PM
  Re: Cant go over 50% throttle...StallingRe: Joe Woods Joe Woods 08/21/04 08:56PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/21/04 09:08PM
  Re: Cant go over 50% throttle...StallingRe: Robert Dingman Robert Dingman 08/21/04 11:04PM
  Re: Cant go over 50% throttle...StallingRe: Joe Woods Joe Woods 08/21/04 11:37PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 04:30PM
  Re: Cant go over 50% throttle...StallingRe: Jason Luther Jason Luther 08/22/04 06:36PM
  Re: Cant go over 50% throttle...StallingRe: Ben Van Zoest Ben Van Zoest 08/22/04 08:40PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 08:46PM
  Re: Cant go over 50% throttle...StallingRe: Bill W Bill W 08/22/04 09:34PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 09:50PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 09:54PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 09:55PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:06PM
  Re: Cant go over 50% throttle...StallingRe: Jason Luther Jason Luther 08/22/04 10:30PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:34PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/22/04 10:35PM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/22/04 10:42PM
  Re: Cant go over 50% throttle...StallingRe: Randall F Randall F 08/23/04 12:21AM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/23/04 12:21PM
  Re: Cant go over 50% throttle...StallingRe: Ben Van Zoest Ben Van Zoest 08/24/04 01:59AM
  Re: Cant go over 50% throttle...StallingRe: Graham Mcmillan Graham Mcmillan 08/24/04 04:50AM
