Speedo Replacement
Michael Miehle /
I am thinking of changing the speedo on my QT50, but I am not sure how to select one that will give a proper reading. Are there any that can be calibrated? How do you figure out the gearing is it based on the rim size? or the speedo gear on the hub?
Re: Speedo Replacement
well.. of course it's both the gear in the hub and the outer tire diameter..
