Sachs Transmission Fluid
Michael Nesson /
I have a Sparta Moped that has a Sachs motor and transmission on it. It is a 1 spped.....I want to change the transmission fluid....what is the best type to use and how much?
Re: Sachs Transmission Fluid
ATF (automatic transmission fluid) Type F
Michael Nesson /
How much should I use? Thanks!
Fill through the plastic screw plug on the side. Tip your bike a little to fill it. And fill until it is level with the bottom of the same hole, when the bike is level.
Michael Nesson /
Thanks...if it doesn't rain later...I'll give it a try!
