Help - bad spark plug cable
James Aasman /
I have a 1984 Yamaha QT-50, and the spark plug cable (a.k.a. high-tension lead wire) is loose and does not always stay connected to the spark plug fitting. I believe this is the reason that my moped stalls about every 5 seconds.
The parts dealer tells me that in order to fix the cable I will have to replace the cable and the ignition coil ($65).
Can I somehow fix the cable (prevent it from loosing connection to the spark plug) without buying a whole new cable and coil?
Thanks
Re: Help - bad spark plug cable
depending on the type of connector
your spark plug wire should unscrew from the cable
just turn the part to come off counter clockwise and cut a little bit off then just screw it back on by turning it in the other direction
That's not going to keep it from falling off the plug.
The connector itself is bad. See if you can find just a replacement connector.
