hole in fuel tank.
the honda express I looked at has a hole in the top of the tank about the size of the tip of a tack.I dont think it could leak much more than a drop a hour if it was suspended upsidown.upsidown is the only way it could leak since it is on the top of the tank.My dad thinks this is a huge deal,is it?
Re: hole in fuel tank.
it isnt good to say the least...
--cb-
Trevor Dickinson /
i would think not. you could seal it pretty easy i would think. perhaps even good old duck tape would work
Not really, the gas cap has vents in it so that air can get in the tank during normal operation. Still, it wouldn't be a bad idea to get a kreem kit and seal up the tank. There may be other areas that are weak, or that hole could get much bigger.
Non Essential /
I was planning to seal it with something,what should I use?
JB Weld, should be able to find it at any home improvement store or Walmart. Very easy to use and works great.
Anybody got any tips for sealing a plastic gas tank?
1977 Vespa Bravo if it matters.
Non Essential /
Plastic? never seen a plastic tank before.
J B WELD, This stuff works on just about everything,
http://www.jbweld.net/
Marg Mantashian /
an auto parts store like r&s strauss has both the metal and plastic tank repair kits.
meanddboys
margarossi613
Thanks much, I will look for that stuff tomorrow!
Non Essential /
I got it I am picking it up later.75.00 for it.
