Puch 2-speed
Steve Murphy /
I just picked up a rough Newport II, and notice that the gear noise is quite a bit louder than my one-speed Maxi or my Sachs. Before I go cracking this thing open, is this normal?
The trans seems to work OK otherwise; it starts off OK and consistently shifts smoothly into second at about 15 MPH.
The noise sounds like gears meshing, kind of like when you are in reverse in a car with a manual transmission. It follows the engine's RPM and not drive sprocket's speed.
The bike sat for many years before I got it. I found that the gearbox was just about dry, so I suspect that it may need some work.
Re: Puch 2-speed
See Ya Moped Army /
The crank bearings could be rusty.
Re: Puch 2-speed
Michael Nesson /
I have a 2 speed that runs great. Shifts smoothly at 15mph....I used type "f" transmission fluid (9.5ozs) exactly and that helped with noise and smoother shifting!
