2003 Targa Lx Problems Help!
Please help my targa lx keeps burining spark plugs with causes it to go really slow if not die half the time. Please Help ive went through 6 plugs it will run for about 3 or 4 miles great then just dies basically. Please Help any hints or suggestions approciated. Thanks Brad
Re: 2003 Targa Lx Problems Help!
does it smoke much when it does run? Did you mix gas and oil in the tank, what kind of oil did you use in the injector, and what kind did you use if you mixed gas/oil
hey ray no it doesnt smaoke much and its fuel injewcted so i dont have to i use regualr unleaded gasoline and 2 cycle oil. Thanks .
You cant just use regular 2 cycle oil in the oil injector. It has to be special 2 cycle injector oil. Regular 2 cycle is to thick for the oil injector and wont work.
Hey, H thanks for the info what should i use then?
check the gas, I was in the same situation then I looked in the tank and their was no gas. HA HA
hey corey i'm not that stupid. Thanks anyway.
make sure your petcock is on.
what the petcock? is it the gas on off valve?
yea
the arrow on the petcock should face down
Hey Cory again it is on...any other ideas....anything will help!
you need to downjet. your probobaly fouling your plug. your burning too rich. you can get jets for a few dollars from mopedwarehouse.
hey what is a downjet, what does it do?
also ryan i couldnt find any downjets on mopedwarehouse, was i looking it up wrong? Or is there somewhere else?
"Downjet" is a term describing replacing the main 'jet' in your carburetor with a smaller one.
Do you know what kind/brand of carb you have?
Any idea of the jet size?
Robert Dingman /
Hey brad just make sure ur running injecter oil thats what happened to me
Have you added anything I mean anything to the moped. And if so tell me.
