Re: 1976 batavus clutch repair
Ziggy F /
Leaf spring serves only one purpose- to make clutch running quiet, you can safely run ped without it.
As far as clutch not engaging, make sure the distance between starting arm and clutch is about 1-2 mm if it's more adjust your starting cable or you can bent that starting arm to serve your needs.
Z
