1976 batavus clutch repair
Marg Mantashian /
I am trying to repair the clutch on my batavus intercycle. I am wondering if anyone has any diagrams or advice for fixing this problem. It was engaging when i pulled the handle, now i get nothing. A piece came out. It is called the leaf spring by the parts specs. I don't know how to reinstall it. Any help would be greatly appreciated. I would hate to junk the moped because i don't know how or where to get help. I don't have a lot of money to invest in this moped. However, it has been great trying to bring it back to life. Please help!
Re: 1976 batavus clutch repair
Leaf spring serves only one purpose- to make clutch running quiet, you can safely run ped without it.
As far as clutch not engaging, make sure the distance between starting arm and clutch is about 1-2 mm if it's more adjust your starting cable or you can bent that starting arm to serve your needs.
Z
Ziggy, I thought the leaf spring engaged the starter clutch?don-ohio
I used to have one and I never had a leaf spring.
still worked fine.
although I stripped out the clutch hub 2 times cause of a slightly bent shaft. haha
