puch wont spark
Rayn Kozikowski /
i just put on my new 1 speed tranny and hooked up all of the wires and i got no spark! when i turn the flywheel and push the horn the horn makes noise, so i know im getting electrical current. i know the coil is good and everything is hooked up like its supposed to be. any suggestions???????
ryan
Re: puch wont spark
Check the contact points, sounds like they need to be cleaned and adjusted or maybe replaced.
Re: puch wont spark
double check your wiring it may be a loose or frayed dammaged wire
Re: puch wont spark
Jason Luther /
start with the easy, obvious things (kill switch) they are often the reason. is it grounded properly? you probably just knocked a wire loose-jason
Re: puch wont spark
Rayn Kozikowski /
alright i cleaned out the points and now i have a strong spark. but now i tried to start it and the clutch wont work. now it wont start and i wanna drive sooo bad. what do i do?
