magnetto bad???
Kevin Persinger /
so i'm working on a anchor hero and i think the magnetto might be bad, is there a way i can repair it???
Re: magnetto bad???
ಠ_ಠ Jon Folks ಠ_ಠ /
Doubtful its the magneto. If it is, yes you can, you need a flywheel puller. Clean the points. Alot.
Brooklyn
Re: magnetto bad???
Most of the time it's the contact points, needing cleaned or replaced.
Re: magnetto bad???
is there any way to test tomos condensors?
I just ordered a new one from themopedjunkyard.
before I took it apart the moped would start and run, but it would not start when it was hot.
I heard that condensors don't work when they're hot if they're bad. so I bought a new one. now I have no ignition at all.
is it possible to be bad even if it's new?
