need help with honda nc50
hello,
i need help with a problem. i am buying a really old moped that seems to have one problem. it will start, but shut off if you don't spray fuel into the carb. the guy i am buying it from says the carb just has to be cleaned. is this true.
thanks, -dale
Re: need help with honda nc50
most likely. And the carb on this moped is extremely easy to take apart, clean, and put back together.
Jonas Quimby /
Once again I direct attention to my guide to fixing a garage sale express.
https://www.mopedarmy.com/forums/discuss/read.php?f=6&i=5035&t=5035
If the bike starts at all then you should be able to fix it up well enough.
Leon Swarmer /
could easily be crud in the fuel tank/petcock/lines too
*most likely. And the carb on this moped is extremely easy to take apart, clean, and put back together.*
How can you you tell what kind of carb it is from all the way over here?
