Tomos headlight help
Michael Dejonge /
My headlight is out on my Tomos Sprint. I put in a new bulb, but that didn't do the trick. As far as I can tell, all the wires are connected. Any tips?
Re: Tomos headlight help
The contacts in the switch may be dirty. There is a screw underneath the switch. Remove that and the switch assembly will lift out. Look at the underside of the assembally, and slide the switch. There is a small part that has a screw on it remove that screw to get to the contacts.
Be carefull at this point, there are small parts with springs that are easy to loose.
Then lightly sand the contacts, and reassemble.
