Leak with 78 Honda Express
I have a 1978 Honda Express that had been running great for a while, almost always started on first try. I recently changed the transmission oil and it still ran great after that. Then I was trying to install an inline fuel filter and ended up messing up my petcock so I had a gas leak problem but I replaced the petcock and it was running fine and no longer leaking gas.
However recently it just started leaking oil onto the garage floor. I have no idea where this leak is or could be coming from. I premix my gas because I am unsure of the state of my oil injector so this cannot be the from the fuel/oil tank. Maybe this is from the transmission?? I have no clue...any help would be greatly appreciated.
Re: Leak with 78 Honda Express
Jonas Quimby /
I had my Express begin leaking oil from the breather tube coming out the back of the tranny. I am not sure exactly why it did this, but I think it had something to do with the fact that at the time I had a mix of a too thick oil and the right oil in the tranny. After pulling it apart and cleaning it out it stopped.
After looking at it again I guess it looks like it could be the oil/gas mix and it normally comes out somewhere below the carb/head. It may be coming out the overflow tube but I don't understand why my carb would be have an overflow problem....
Jonas Quimby /
I dont mean the carb overflow, I mean the transmission overflow. Look on the back side of the tranny (the side that faces the wheel. There's a plastic nipple with a rubber hose attached to it. That is the transmision breather and overflow opening.
Leon Swarmer /
if it is just oil its a tranny problme.
if it is the mix you could easily have a valve in the carb that isn't seating properly. or a float that won't let it seat right.
Leon
Jonas Quimby /
Cept the Express is oil injected.
Oil never enter the carb.
I already said though that I premix that gas, so the oil would be entering the carb. Also, I mentioned after your comment that what is leaking appears to be gas/oil mixture so that is why I mentioned the carb overflow...
Jonas Quimby /
ahh, I'm not very good at putting details together early in the morning and such.
Anyway, I have had my bike begin to leak many times in the past.
The most common problems are that the passage the float needle seals is too dirty for a good seal, the needle itsself is worn out or that the float has sprung a leak and wont float.
If this is the case then gas will be leaking out the overflow tube that runs down the front of the engine
