Puch Brake Adjustment???
Michael Nesson /
I need to adjust the tension on my Puch Maxi and was wondering how to take up the free play? Is it hard....anyone with ideas, please let me know! Thanks
Re: Puch Brake Adjustment???
Ben Van Zoest /
Each end of the cable has adjusters that take up slack.
Michael Nesson /
Which end do I start with? It seem the slack is in the hand levers? Do I loosen the coupling and adjust from there? I'm new at working on peds!
I'd let all the slack out, then shorten the brake cable a bit at its attachment at the wheel.
That should allow you to make future adjustments with the cable adjusters.
Ben Van Zoest /
Yes, if the cable is stretched beyond adjust limits you'll end up doing a slight modification on the wheel end of the cable.
Namely the lug will be useless and you need to make a new end stop with clamp. I gave this tip to a friend it worked for him.
Michael Nesson /
Will try these suggestions later today! Thanks!!!!
