cleaning out the fuel tank
whats the best way to clean out the gas tank. i dont want to use water because i am afraid it will rust it out
Re: cleaning out the fuel tank
FIll it with gas, shake it around alot n pour the contents out quickly, repeat as needed
thats expensive
Its worth it and most tanks dont hold very much and you only need to put in like a third of a tank
That will work, or you can just use water and then use a hair dryer or something to get it dry quickly. If it has rust inside, just flushing it will not solve the problem, because it will eventually rust some more.
If you go to a local motorcycle shop you can find a thick milky substance they use to coat the inside of the tank to prevent further rusting, i forget what it's called but it has always worked for me, just follow the instructions carefully.
kreem
i always use water on a rusty tank. i mean heck it's already rusted. there are many gas tank sealants available at your local hardware store, however i never use them. i just get all the rust out and keep the tank full.
if you can remove the tank, fill with a LITTLE gas, some degreaser or whatever you want to dump in the tank
add some deck screws( or anything like that) dump like 50-60 screws in the tank, and shake the shit out of it and rinse
works good, i've gone as far as to buy an old rotisserie for a BBQ grill (the ones with the little motors) and make some kind of jig to hold the tank and just let her spin, and spin
comes out shinny new
i do allot of work on old motorcycles so the tank being removed is never an issue.
other than that you can use acid, baking soda and H2O
but be careful
this is hard to do if you have a built in tank like me
