Re: Rizzato Califfo 80
David H /
On the twist part of the throttle you will see that slanted groove line. There should be a little piece with a screw that will sit in that groove. You run the throttle cable through that piece and tighten the screw so it holds the cable then when you turn your throttle you will see the piece slides back and forth in the groove. Hard to explain in words but hope this helps a little.
